Прошивка 4.4.1 для LERDGE-X/K/Z
Скачать прошивку
Процедура обновления прошивки
After updating the firmware, you need to restore the factory settings and reset all parameters through the display.
После обновления (лучше и до) необходимо сбросить параметры на заводские и задать параметры через экран.
  1. The internal storage space is re-planned. After updating the firmware, you must restore the factory settings and reset and level them.
  2. Rewrite the material detection filter algorithm to reduce the false alarm rate of material detection (currently in the test version)
  3. Increase the mileage statistics of each axis, which can be viewed in the system information (currently in the test version)
  4. Change the high-level duration of the pulse signal of each axis from the original fixed 3us to a dynamic change with the pulse frequency, so as to be better compatible with more drives
  5. Reduce the pulse upper limit frequency of each axis, from the original 180Khz to 150Khz (mainly a compromise made to be compatible with the dynamic adjustment of the pulse time)
  6. Add the function of automatically raising the Z axis after exiting the leveling interface to prevent the possibility of directly heating the print head after leveling and causing the printing platform to be scalded
  7. Add the homing icon indication function on the main interface
  8. Optimize the tool setting accuracy during pause and unexpected power failure, after saving the printing progress, when continuing to print
  9. Added support for M73 command to display remaining time (for prusaslicer slicing software)
  10. Fix the bug that the temperature is reset to zero when resuming printing after the temperature error is paused
  11. Repair the recovery error bug that occurs when the refueling action is not completed and clicks to continue printing when the refueling is suspended
  12. Fix some display errors
StarCom
Re: Прошивка 4.4.1 для LERDGE-X/K/Z
Сообщение StarCom »
Пакет локали от предыдущей версии подходит?
StarCom писал(а): ↑08 май 2022, 18:05 Пакет локали от предыдущей версии подходит?
Вряд ли. И вообще, если речь о русификации - сильно не рекомендую к использованию. Очень много было жалоб и 2 раза приходилось полностью возвращать к жизни после неудачных попыток установок клиентами.
StarCom
Сообщение StarCom »
Накатил локаль lerdge_UI_V4.3.3~V4.3.6(EN-RU) на 4.4.1 все норм!
evg
Re: Настройка режима SensorLess Homing (только Lerdge-K)
Сообщение evg »
Плата Лердж-К. 2.0.1
драйвера Лердж 2209
Прошивка 4.3.3
Была настроена и отлично работала парковка без концевиков.
После обновления с прошивки с 4.3.3. на 4.4.1 парковка без концевиков перестала работать.
homing load test и position load test показывают - 160 и 70.
Как и на предедущей прошивке для сработки значения устанавливаю 90%. но мотор не останавливается вплоть до проскока ремня.
Вернулся на прошивку 4.3.3 но и в ней парковка без концевиков перестала работать. К тому-же homing load test и position load test теперь показывает - 0.
Опять обновился на 4.4.1 .homing load test и position load test показывают - 160 и 70. но парковка без концевиков по прежнему не работает.
Кто столкнулся проблемой напишите как решали?
В службу поддержки lerdge написал.
При обновлении и при откате прошивки сбрасывали параметры на заводские и вводили вручную с экрана?
evg
Сообщение evg »
Да. Делал все по инструкции.
Работу парковки без концевиков на прошивке 4.3.3 восстановил.
Необходимо было после прошивки и восстановления заводских параметров обесточить плату (отключением питания т.к. перезагрузка не помогала). homing load test и position load test теперь показывают и парковка работает.
На 4.4.1 проковку заставить работать так и не смог.
evg
Сообщение evg »
Напишите кто обновился до прошивки 4.4.1.
Работает парковки без концевиков?
Меня интересует - это проблема прошивки или у меня какой-то сбой.
Служба поддержки по данному вопросу пока молчит.
Я написал о проблеме в группе facebook. Тоже тишина.
StarCom
Сообщение StarCom »
evg писал(а): ↑18 май 2022, 22:53 Напишите кто обновился до прошивки 4.4.1.
На ревизии платы 1.0.2 - аналогичная ситуация, вернулся на 4.3.6.1 парковка работает как прежде!
Баг в прошивке 100 пудова.
Вернуться в «Прошивки LERDGE»
