CURA 4.13.0
CURA 4.13.0
- Администратор
Re: Cura 4.13.0
Other new features and improvements:
Improved TPU: top layers have large bridge distance
Add warning icon to show which extruder is causing the configuration to be 'Not Supported', contributed by fieldOfView
Show what's new pages with every Cura build
Speed up loading of settings list
Re-use vertex buffer objects in rendering
Add Build Volume Temperature value to ChangeAtZ, contributed by legend069
Allow plugins to have multiple views, contributed by Tyronnosaurus
Reduced top/bottom speed for TPU
Increased lined width for 0.3mm layer height profiles
Improved logging to allow debugging in early start-up process
Bug fixes:
Fixed a bug with surface mode will not print all layers
Fixed a bug where maximum retraction could cause a crash
Reduced flow for 100% density parts
Fixed a bug in Surface Mode where small line-segments were created
Changed the Russian translation for 'nozzle', contributed by mlapkin
Fixed a visualization bug where layer lines were rendered in weird directions
Fixed a crash when receiving incomplete cloud API responses
Add SET_RPATH option to CMake, contributed by boomanaiden154
Fixed initial layer bed and print head temperature for Snapmaker profile, contributed by prueker
Fixed shader compilation on some GPUs, contributed by fieldOfView
Fixed a bug where Cross 3D infill pattern vertical angles varies wildly
Bridge Skin Density can be set above 100%
Fixed tiny travel moves when monotonic ordering was enabled
Fix crash when using 'Select face to align to the build plate', contributed by eliadevito
Fixed a bug in fuzzy skin where sometimes it produced weird long overshoots, contributed by BagelOrb
Fixed undo and redo for support blockers
Fixed a bug where the Native CAD plugin wouldn't loading
Fixed a bug where the camera view toggle was not visible
Fixed some German translations, contributed by Sekisback
Fixed the link of the beta update message
Fixed a crash due to extruder being out of range
Fixed a bug where a disabled extruder was used
Fixed a bug where the aborted state was not reflected correctly in Monitor view
Fixed a bug in Pause at Height where it stops extruding
Fixed a bug where support blockers were included in the bounding box after loading a project file
Fixed a bug where grouped models become unslicable if the first extruder was disabled
Fixed a bug in Tree Support where the Z Distance was too big
Prevented QT plug-ins from being loaded from an insecure directory if an environment variable is set
Bug fixes:
