- Adjust the corresponding relationship between the automatic leveling points and the leveling algorithm.
Set the leveling point to 0, the system disables the automatic leveling function
Set the number of leveling points to 1, and the system uses the plane equation algorithm to level with three-point sampling
Set the number of leveling points to 2, the system adopts bilinear algorithm, leveling through four-point sampling
Set the number of leveling points n (2<n<32), the system adopts grid bilinear algorithm, and leveling through n*n points sampling - Adjust the material detection logic to reduce the suspension problem caused by misreporting that the consumables are exhausted.
Прошивка 4.3.6 для LERDGE-X/K/Z
Lerdge firmware V4.3.6
