https://github.com/MarlinFirmware/Marli ... /tag/2.0.5
New Features
Quad-Z bed alignment
Boards / Pins
Added E2 stepper pins for Rumba
Improve FYSETC S6 pins and variants, set platform version
Fix default SKR 1.4 TEMP_PROBE_PIN
Allow Z_STOP_PIN override on SKR 1.4
Define a Z_MIN_PROBE_PIN for Cohesion 3D Remix
Configuration
Configurations version bumped to 020005
Sanity-check for Trinamic micro-steps values
Use bed max temp for probe temp compensation default
Move SENSORLESS_PROBING to the probes section
Changed SD_DETECT_INVERTED to SD_DETECT_STATE HIGH to clarify its meaning
Expose BOOTSCREEN_TIMEOUT for character LCD
Added HOME_AFTER_G34 option
Hosts and UI
Fixed build issues with REPRAPWORLD_KEYPAD
Fixed undefined STATUS_CHAMBER_WIDTH
Updated German, Turkish, Traditional Chinese
M220 without arguments prints the current value
Send SD file open message to all attached hosts
Improvements for DGUS displays
Fix Malyan LCD compile issue with PID tuning
HAL / Platforms
Shorten HAL / environment names to reduce command size for Windows
Added early checks for LPC1768 pin conflicts
Added SoftwareSerial for SAMD51
More explicit conditionals for EEPROM types
Fixed STM32 low level _WRITE macro bug
Issues Patched
Fixed SD print crash / freeze (enqueue_P)
Fixed M117 not working in auto[N].g
Fixed longstanding bad line ending handling in Emergency Parser
Fixed a longstanding bug in M810 so it is now usable
Improve reliability of QUICK_HOME with Sensorless Homing
Always look for the power-loss file on boot (even if disabled by default)
Fixed handling of extra axis CS pin auto-assignment
Fixed Z4 stepper indirection compile issue
Fixed G34 decreasing accuracy, probe range bugs
Fixed ADC calculation for AD595 / AD8495
Fixed a bug with synchronizing the E position
Fix build with 3 auto fans
More fixes supporting 8 and zero extruders
Make M114 non-blocking so it won't affect prints
Change PID "dummy" value to NAN (not 3000.0)
Optimized / Improved
Improved MarlinMesh.scad mesh visualizer script
Improved SD print completion handling
Minor string usage optimization
Optimized and improved M900
Added Max7219::suspend and resume methods
Fixed Max7219 init animations to be non-blocking
Init the SD card on an external controller later
Apply soft endstops to joystick jogging
For Developers
Modified ENABLED / DISABLED macros so they can be used in C++ code
Added logging for setup() with MARLIN_DEV_MODE enabled
Added missing pins to the pins debug list
More liberal use of loop shorthand macros
Added build tests for GTR Pro 1.0
Moved some 2560 tests to 1280 for balance
prepare_move_to_destination renamed prepare_line_to_destination for consistency
position_is_reachable_by_probe moved to Probe::can_reach
Marlin 2.0.5
Marlin 2.0.5
Re: Marlin 2.0.5
Re: Marlin 2.0.5
2.0.5.2
https://github.com/MarlinFirmware/Marli ... ag/2.0.5.2
New Features
New Controller Fan options and M710 G-code.
Add M42 M to set pin mode.
Boards / Pins
ARMED support for TMC UART, probe temp.
Future-proof pins files with HAS_TMC_UART.
Add Copymaster3D board.
Stay at version 0.91 of USBComposite for STM32F1.
Use pin/port names for CHITU pins.
Add USB serial support to SERIAL_PORT_2 on DUE.
Add SoftwareSerialM for MKS Robin TMC UART.
Configuration
Sanity-check backlash for core kinematics.
Hosts and UI
More decimal places for babystep / Z probe offset.
Fix FYSETC mini 12864 init / glitches.
More DGUS updates.
Fix limits on acceleration editing.
Issues Patched
Fix Emergency Parser on DUE / SAM boards.
Fix MKS SBASE 1.6 E1 heater pin.
Fix extra line in M114 output.
More reliable sensorless homing with Core kinematics.
Implement CONTROLLER_FAN_USE_Z_ONLY.
Fix include of custom version file.
Skip PWM pin sanity-checks if they can't be done at compile time.
Clean up and improve M43.
Tweaked serial port descriptions in configs.
For Developers
Split up STM32 pins files by model.
Added a node script to apply pins file formatting.
New Features
Boards / Pins
Configuration
Hosts and UI
More DGUS updates.
Issues Patched
For Developers
Re: Marlin 2.0.5
Marlin 2.0.5.3
https://github.com/MarlinFirmware/Marli ... ag/2.0.5.3
New Features
Add QSPI EEPROM for SAMD51.
Case Light brightness stored in EEPROM.
Issues Patched
Fix Max7219 delay timing.
Remove extra call to unskew.
Formbot T-Rex 2+ default LCD timings.
Fix M0 unused var warning.
Fix stepper PWM menu.
Float pins that can't pull down.
Fix bad final M2/M3 Arc segment.
Simplified SD completion.
Configuration
Allow PID_DEBUG to be turned on/off.
Boards / Pins
Funmat HT v4.0 board support.
Fix up Trigorilla 1.4 pins.
Fix FYSETC STM32 flash usage.
Fix PINS_DEBUGGING build on STM32F1.
Hosts and UI
Update Russian and Italian languages.
Fix SD finished ExtUI / host action.
Limited backlash editing with Core kinematics.
Fix / improve FTDI EVE Touch UI.
For Developers
More runtime TERN macros.
New Features
Issues Patched
Configuration
Boards / Pins
Hosts and UI
For Developers
Re: Marlin 2.0.5
